4410 JD Hydro Drive not working
TennTractor
New User
At question is a 4410 Compact JD with hydrostatic drive. The battery has been down on this tractor but will readily start and run fine. However, the tractor will not move forward or reverse, period. This is something that has happened suddenly. No slippage or issues prior. The tractor does sit unused for sometimes weeks in between uses. Any suggestions?
Hydro fluid checks ok and is clean. Always use a trailer rather than tow. Going to go ahead and install a new battery. I know there are some electrical servos in the system and the hope is maybe the bad battery could be causing them not to function properly.
I have a PDF of the Deere Tech manual you are welcome to.
If wanted, just shoot me your email
Joe
Roger, I can't thank you enough for the service manual! Troubleshooting now starting with the electrical on the pedal switch. Thanks!!!
