30/40 Ejectors
I thought they did too on a 40 but have been our of it for 14 years.
I think they may have added some extension angle irons to the bottom of the bale case to help capacity.
Guess we should be looking at parts catalog and see what is different.
(quoted from post at 17:40:03 07/23/15) I thought they did too on a 40 but have been our of it for 14 years.
Yup, I agree on looking at the parts list. I went there first(jdparts.com) and could not find the 40 ejector. I was able to find the 30 and the 42...Maybe It's there and I am not seeing it. Thats why I'm here...
WOW....
I got it now!!!
I can't belive I did not see it before. Then again, I have never clicked on "exact model search" either
Thansk!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Just went though the parts list. Other than a few minor mechanical difference (such as the lock that sused to lock the unit from kicking) everything is the same other than the pump. Same control valve and everything else.
The pump that was on the 30 ejector subs to the same pump thats on the 40 ejector. In other words they are the same units. The 40 ejector also had the electric option which could of easily be added to the 30 ejector.
I think a 40 has a heavier spring setup to put bales in the back of longer wagons. You see alot of 40's that are welded up or cracked more so than 30's.
There were some bale case extensions that tip up the bale coming out of the bale case. That allows the throwing pan to come
under the bale rather than hitting the bale and malfunctioning. Helps when really pushing the output of the baler.
You were right, the lockout was added so you could lock the ejector from either side of the bale case.
