newgenjdcollector
So I have been working on restoring my 72 4000D the past few months. Got it all painted and put back together enough to start it. First start, it started well. Ran a bit and fluttered some. I didn't give it much thought because I figured it may have some air in the line from being off, new filter etc. On the next start it flutters bad, changes rpm a bunch and dies and will not re-start. I start checking for the click in the fuel pump and don't hear much going on. So I took the cover off the pump and took the solenoid out. Hooked it to hot and ground and sure enough, it doesn't have the strength to pull the flapper closed. So I order a new solenoid, thinking that would be the end all cure (btw the new solenoid design is way better than the original). Anyhow, so I put the new solenoid on and the tractor fired right up. Then it proceded to flutter a bit like before. Again I didn't think much of it because of having the pump cover off, etc. I pull the tractor outside and it died again. Before it died, I noticed it didn't seem to have much power or pep. The engine sped up very slowly. This time, I could not get it re-started for nothing. I cracked injector lines, I opened fuel lines, I tried priming, nothing helped. I took the cover back off the pump to see if I maybe got the flapper in the wrong spot, but I couldn't really tell anything. As soon as I put the cover back on the pump and hit the key, it started like nobodys business. It ran a few min pretty nice and died again. Every time it dies, it's incredibly hard to get started. Each time I crack the pump cover, fuel runs out, but nothing ever coming out the top elbo (overflow?). I blew air thru the orfice and it's not obstructed. Have never had this kind of trouble before. I'm at a loss and wondering what to look for.
