I am trying to replace my water pump on my 720 pony motor. I ended up cutting the bypass pipe and the inside bolt in order to get the cap off, but I can see that there is no way the inside bolt will go back in without pulling the engine to clear the governor.
I have never done this before, so I would like some guidance on how to do it, like what bolts need to be removed etc. I already have the steering arm off and the tractor sits under a beam in my barn.
What do you attach the chain too on the pony motor to pull it?
Do I have to remove the starter, or can that be left in place?
How do you remove the exhaust pipe?
Does the instrument dash need to be removed?
What gasket do I need to purchase before I reinstall the motor?
Can I cut that little pipe between the water pump and block? I don't see another way to remove the pump. It won't budge a bit with that pipe.
