James Howell
Take a look at the diagram below.
Note the oil seal (Key 8) and the clutch housing (Key 23).
The oil seal is leaking and a small amount of 140W transmission oil is mixing with the 10W PTO oil.
The oil seal is being replaced.
Note the powershaft (Key 1), cam clutch (Key 15), clutch drum (Key 27), and the clutch drive disks (Key 33).
The clutch drum was slipping and all the clutch drive disks were replaced.
The clutch drum continued to slip and the cam clutch was tightened (clockwise) according to the service manual instructions.
The clutch drum still slips and the powershaft will not operate.
The first question is [b:654c4848f0][i:654c4848f0]could the heavier oil from the transmission cause the clutch disks to slip?[/i:654c4848f0][/b:654c4848f0]
The second question is [b:654c4848f0][i:654c4848f0]will the heavier oil from the transmission cause any damage to the faces of the new clutch disks?[/i:654c4848f0][/b:654c4848f0]
