salvage yards for JD rotary cutters
Do not mean to offend, but my thought on reading this post is there is nothing as wore out as a used rotary cutter. Ones I've wore out are good for nothing but cutting up into scrap. Frames are vibrated tp pieces, seals leak and gear boxes run dry,.etc.
I understand that people beat those things up and wear them out. Not the case with my equipment. I did hit a stump in an area I usually do not hog that I did not see and broke the shaft. Serial number is 010610. Appears the part number is de19036
