fixerupper
The PTO wouldn't pull the Bushhog anymore so I had to bite the bullet on a new clutch. Right before I left the shop tonight I saw this scene and snapped a pic just because. I like to do things neat clean and orderly. Tomorrow new axle seals go in while it's apart. This baby is going to be expensive!!!
The main question I have is about the healthy sized spring that hooks to the left three point hitch lift arm and goes down to the left side sway block. How do you get that bugger back on? It has been off for many years, ever since the mounted corn picker days that ended in the early seventies. I want to put it back on when the tractor goes back together but I don't know the trick. The three point has worked fine without it but I want it back on just to be original. Jim
