60 power steering oil goes into engine
Bought a 60 that had been sitting in a shed for 25 years. Neighbor mechanic got it running agian, he filled it with oil for the power steering, said everything worked. I painted it last week, power steering didnt work was out of oil so I added more and it worked great drove tractor 6 miles no smoke what so ever. Drove in tractor drive the next day, and noticed right away it smoked a little. After drive I parked it, after few days started up and it really smokes bad and had no power steering again. Figured out it is dumping oil into the engine. So I let the oil level valve drain into bucket and about 3 1/2 gallons came out until it stoped. Where is the problem, Is it the seal on the pump by the fan or how else can oil get back into the engine from up front? Not a drop of oil leaking from up front.
Blake,
My 70 was leaking too only mine was blowing oil out the PS resivore cap. Seemed to be holding PS oil OK but crankcase would get low. First I thought it was coming from the pedistal
seal but later after taking the hood off saw it being blown out the vented cap.
Pump seals.
Pay close attention to how they go in. I put one in backwards one time. Second try was easier - I knew all of the shortcuts to get the pump out.
