Hello, I have a 38 G that I am restoring right now. The tractor had sat for several years and the cork gasket behind the flywheel is leaking. To get to it, I have to remove the flywheel obviously. I got the two bolts off of the flywheel already, now to get a puller on there and pull the flywheel loose. I was reading somewhere that there is a "specific" way of removing and installing the flywheel back on. I don't have a IT manual for it, but other than removing the flywheel, replacing the gasket, making sure everything is lined up the way it came off, setting end play, and tightening the bolts, am I missing something? After I read how there was the "specific way", I got a little nervous I was doing something wrong. Anyways, any input is appreciated or tips would be great. Thanks!
