720 diesel governor
I was working on my governor last night and after I removed the 2 slotted screws under the access plate holding the inside governor lever to the inside governor shaft I dropped a screw. not sure where but it wasn't in the housing. Went down into a port or opening someplace. I'm worried it went into the cam gear area. These screws are difficult to handle and I'm sure I'm not the first to lose one. Now what?? Should I lose sleep or will it end up in the bottom of the pan sooner or later. Thoughts? I haven't ran it or drained the oil.
