JD Model H spreader problem
Bob Kerr
I had the gear case for the feeder chain blow apart. I need the whole case and gears if anyone has an H spreader they are going to gut and use as a people wagon or one rotting out in the back 40. I use it to spread Black walnut hulls in the fall. Can't afford to be without 2 working spreaders. One pickup load of nuts will fill the spreader full of wet hulls, and I sure don't want to have to shovel them out again. Anyone got one?
The shells go to Missouri to be cracked open and the nut meat taken out. The hulls (the green/ brown part)I spread on my yard and some of the neighbors. Not much market for those. One good size pickup load of nuts fills the spreader, so with a few trucks in one day, I could have a big problem if my other spreader breaks. Just wanting to get the broken one fixed before fall.
