plow (plough)
DaveH IA
What # followed me home today ? The cyl brackets have been added and will be removed
[/img]
That's a neat plow. What are the beam numbers?
I've never seen a factory JD hydraulic cylinder lift mechanism adapted to a JD plow of that vintage. Looks like you'll be needing a master
lever for your plow. I have one from an early NO. 4 or 4A if that would help you.
Tyler in IL
(quoted from post at 20:39:10 07/01/15) That's a neat plow. What are the beam numbers?
Tyler in IL
# 457 on the front bottom beam --haven't found the # on the long beam yet gonna try to weld the lever its been repaired before---
I have a 3 bottom plow like this one. It has the bottle cap wheel. I have seen old literature that shows the plow being pulled by a spoker D.
