My 1070 clutch appears to be stuck after setting idle for over a month. I have found on my older tractors that blocking the clutch pedal and periodically hitting the starter when in gear that will break them loose. Problem is I cannot hit the starter when in gear on this tractor. I see there is a neutral start switch and a neutral start relay in the system Where are they and are they easily accessed? Which do I need to disable and how?
Is there another way to hit the starter with the transmission in gear to jolt the clutch free? Any ideas or experience here?
