livetowork63
New User
I have a F935 that ran great until a couple of weeks ago, when it overheated. I let it cool down, pulled the thermostat, added coolant/water. It started right back up, then ran for about 30 feet, then shut off. I haven't been able to get it started since. I checked the fuses, all connections, cleaned the injectors, checked the glow plugs which are fine, and bled it out.
It seems not to be getting enough fuel to the injectors. There is plenty of fuel up to the pump, and the bleed screw was just replaced.
Any advice ?
Any advice ?
