old fashioned farmer
Howdy again,
Well, I spent part of the day messing with the old girl again to figure out this issue of coming out of gear while going downhill and then coming back in at the bottom. I tested one suggestion of putting the tractor in 6th and holding the brakes to see if the clutch slipped before it started lugging down. No slippage at all. I then hit the long hill down to the barn to run through all the gears. I thought I had done this already but had not so, sorry if I said I had earlier. 1st gear...started rolling, 2nd gear...started rolling, moved to 4th (on left side of shifter quadrant)...started rolling. I moved to the right side and tried 3rd...no roll. Wait a minute. I moved on to 5th...no roll. Did the same in 6th. On the way back up the hill I tried reverse and there was no roll there either. I thought it had to be in the shifting forks or rails or something so I took it to the shop and proceeded to pull the top cover and have a look. I couldn't see anything odd or seemingly wrong. I went to my shop manual to make some comparisons and do some tinkering. I discovered that my three gears that seem to let go are all tied to the others that don't. Hmmm. Also, two of my rolling gears (2nd and 4th) are positively locked. Meaning that the only way to pull them out of gear is with the shifter itself. I put them in gear and then tried to push them with a pry bar and could not until I unlocked the spring loaded part of the shifter. This throws a whole craftsman toolbox full of wrenches into this mess. Why would only 1st, 2nd, and 4th come out when all of those same shifters work on the other side of the quadrant? It can't be a clutch issue, otherwise all of my gears would do this but my gears can't just pop out either with the positive locking on the shifter rails. Any new ideas would be greatly appreciated. I will keep studying my shop manual to see what I am missing. Got to be something. Tractors can't be possessed....or can they?
