2010 Forklift clutch adjustment
I have a 2010 forklift with HLR transmission. foward backward movement controlled by reverser but when in foward or backward position, pushing the clutch in does not disengage movement. How is this adjusted to work properly? I believe this is a hydraulic clutch in this tractor.
It appears machines with hyd reverser had a disconnect clutch to be used to disconnect engine from trans. It is adjusted by altering position of cam(parts key 3)
