I have a JD 2010 with loader + JD 50 backhoe sitting at my yard, and considering fixing it as I need to do some digging around the property. The tractor has the gas engine. The previous owner said in passing that "it needs a new motor", but did not give any details. The exhaust is broken so rain over the years has likely entered the engine, on top of whatever other problem there was.
The main piston on the backhoe has some very light pitting, would that be a big deal for the seals? I"d also like to know the digging depth and weight of this JD50, if anyone knows the spec. What other tractors does it fit, apart from the JD 2010?
Im trying to decide if it"s worth embarging on a restoration project to put the machine back to service, any thoughts welcome.
Thanks!
Thanks!
