Hay hay hay
My JD 5420 has started to lose fuel prime when it sits overnight. A quick bleed and a couple dozen pumps and it will start right up and run fine. The tractor will start all day but lose prime overnight.
It happens when sitting level, does not happen as much when sitting on a slope with the left side lower, I do not keep the fuel tank full, seems to happen less when the tank is more than half full.
Any ideas what is causing this and what to do?
