Old greased parts '37 A
Navajo350
In my '37 JD A steering box, there is a lot of old grease in there from over the years. I'm getting a new worm gear bearing and I will pack that full of grease. Is it advised that I can leave the rest of the steering pedestal alone and after just pump it full of new grease with a gun? Or should I go through it and clean all the assembly out? What works best for cleaning it out?
What about the same for the front wheel hubs and bearings?
Thanks,
Robert
If you're a jockey just wanting to pass it along you could do that. I woulden't. BTW - IF you're talking about chassis grease from a grease gun on a worm gear you'd be better off filling it with sawdust and calling it good. 00grease is as heavy as you can go without it pushing away and running dry.JMO
(quoted from post at 06:19:14 06/28/15) If you're a jockey just wanting to pass it along you could do that. I woulden't. BTW - IF you're talking about chassis grease from a grease gun on a worm gear you'd be better off filling it with sawdust and calling it good. 00grease is as heavy as you can go without it pushing away and running dry.JMO
I have red bearing grease
