Hotflashjr
- Location
- Western MA
Went last night to drive the 1020 I asked about earlier this week. Turns out it is a 1966 gas, power steering, mid pto. Dual stage clutch works just fine, 3 pt stays up great after shut off. I weigh in at 200 lbs and could not get it to budge with all my weight on it wit the tractor off. Lots of new parts on it and it ran and drove great. It has 2020 rubber/rims and rims on it which puts the rear end up a bit higher than stock. I got an original top link, wheel weights and enough hy-guard to change the trans fluid as part of the deal.
That's the good. The bad is fenders are rough, lights do not work, and the horizontal exahust has a leak at the manifold. After some looking it seems unless I can find a used manifold I may have to go to upright or find someone to repair the manifold.
