Mitch D
Neighbors 336 can't throw the bales into the wagon. Thought it was something in the valve so we just switched it with ours so he could go get baling (rained as we where bolting it in) but still don't work. The pan slowly comes up and then is very slow to go down, don't get down before next bale comes. Thinking about swapping the rams? Not much else it could be is there? Anyone else run into this?
Thanks Mitch
Ram is only powered up! Spring inside of ram sends it home.
Sounds like pump is not putting out volume. Is suction hose to pump collapsing or crushed. What is condition of filter in tank?
Pump may be worn out.
