I can not get the starter to engage through the ign.switch. Small solonoid {located next to clutch pedal} will click,got current to small terminal but will not come through to the larger terminal that goes to starter solonoid. Have installed new solonoid {from Deere} and still have the same problem. When I cross the starter solonoid I can get it to kick in and start. I have got the neutral switch bypassed. All ground connections are good as I can tell. Anyone had this problem? How to fix?
Yes this tractor has been setting for some time,but I can get it to run by jumping the solonoid on top of the starter.
The starter is Nepandenso {not Delco}
All help appreciated.
Thanks
Thanks
