Hello all. Got an H with an XB distributor that doesn't want to start.
Still 6V, positive ground. Electric start.
Distributor has new points and gap set correctly. Started just fine 2 weeks ago, but when I needed it to move today it wouldn't fire at all. Not a pop. When I pulled a plug and grounded plug while cranking engine, I got no spark or very sporadic spark at best. Only difference that I can think of between the last time it ran and today is that air was a lot more humid. There was a little moisture (droplets) on the inside of the distributor cap when I took it off today.
Checked and had 6V going into the terminal on the side of the distributor.
Newer plugs but original wires and distributor cap.
Body of distributor was very hot after making several attempts to get the H started.
Is there a good way to check the coil? Something else that could go wrong and cause coil to noticeably heat up?
If it ends up needing a new coil or cap, where's the best source for reliable replacement parts?
