John Deere G Flywheel oil leak and flywheel play
Circle K
Hello, I recently got my 38' G out and running which hasn't been ran in a few years. Once I got it running, I had an oil leak coming from behind the flywheel. So I would assume that I need to get a new cork gasket for that. However, I have a little bit of play in the flywheel on the crank. This might be a dumb question but how do I get rid of that play in the flywheel? Thanks in advance
To reduce endplay, the flywheel needs to be moved inward a bit on the crankshaft, before the bolts are tightened, after replacing the seal ring.
You will need to hold the clutch pulley towards the tractor when adjusting the endplay at the flywheel.
