I have a little Case W7 E Payloader that has had the power steering changed. The change is that a Char Lynn flow divider--not sure if flow divider is the correct term. Two hoses in and two hoses to the rear two hyd cylinders that turn the rear wheels. This Char Lynn is down under the steering wheel where a steering box was located and now removed.
The tractor has a VICKERS power steering pump that has gone bad.
QUESTION
COULD I just plumb the power steering into the hyd. system that runs the front loader and bucket and have that oil go to the Char LYNN flow divider??
Thanks for any thoughts and ideas..........
QUESTION
