luc rear crank seal
suspect my rear seal is leaking on my luc. hasn't ran in years and am getting it going again. the seal hasn't been available since 1952 from deere. haven't tore into it yet, does anyone know if it is just a normal lip seal that a bearing supplier could get or is it something special? if special where does a person get it?
thanks
I could be wrong, but I believe it is the same seal as used on the LA engine which is avaiable from Deere. AL2654T was replaced by AT195T.
got new seal and installed today. gave bearing supply shop the skf# from bob and he had to order one. the one he got me is a TMC 35442VC it has rubber around the OD of the seal too. once i got it on the shaft i was able to press it pretty well all the way on with firm hand pressure like you can with most seals that have the rubber OD.
