I have a 1948 John Deere B with a 45 series 1 loader. Obviously without power steering, it's a bit difficult to use with a heavy load in the front. I thought I might replace the current steering wheel (which has an outside diameter of approximately 16-17") with a John Deere 70 steering wheel with an outside diameter of 20" in order to change the steering ratio. However, none of the 20" steering wheels list the John Deere B as a compatible tractor. With that being said, the specifications for each appear to be nearly identical. Is there any reason why I shouldn't try a 20" wheel with the B?
