This is LONG......
After reading & hearing about all these 630's with main bearing issue's after the crank case gets washed
out from gasoline & fuel shut off diaphragm failure. Which has happened twice to this tractor in the last
10 years. But it was caught rather quickly, because I watch things like this & check oil's be for using any
tractor. I've noticed HIGHER than normal oil pressure on this machine which made a lite come on in my brain.
Thinking the O ring seals were swelling shut & transmission had been making oil. This tractor also has a knock
with the PTO disengaged but quiet when the floor shifter is engaged. Having 10 of these 2 cylinders on the farm
we just haven't used the 630 too much thinking something was wrong & having the time to go over it.
I started by ordering gaskets & seals 1st , clutch kit. Tore the tractor down with 1st reduction cover off,
clutch driver on the crank, Made a device to hold the cam shaft in place started the engine to see where the engine
oil is coming from, sure enough the main bearing quill had a track of oil at the main case. Check main bearing
clearance OK on both side.. Replace'd every thing & check for leaks OK.. Oring were swelled some but still had a 3/16
hole threw them but RH side the oring was cracked. LH side wasn't cracked & not leaking but now replaced.
Now for the noise/knock... The only thing turning is the PTO drive gear off the crank shaft. After checking/study
measuring & not having all the nessasary tools required in depth. At some point in time the upper R-20178R clutch
fork spring Broke & somehow a piece went threw the crank drive gear & the constant PTO gear (I think)?? NO Damage marks
on either gear. But after spinning the PTO gear I noticed it was slightly out of balance. ( Maybe they all are?) Bearings
are perfect, But I got new ones & tried it, knock is still there. When the PTO floor shifter is disengaged. Engaged
perfect or as perfect as a 2 cylinder can be.. I'm getting bother upper & lower new springs from a dealer in Iowa. Ob new stock.
By added the Load to the PTO gear Noise is GONE.
I chucked the gear up in our brake lathe at work using a dial indictor checked each tooth & I found it's egg shaped ?
Where I started to check @ .0000 it goes to .0017 & at one point -.0004. I've found a used gear & it's not a lot of money
plan to try it, I am thinking I should also do the crank drive gear too? But again I can see nothing wrong with it. I am
unsure it's even possible to egg shape a gear this size, I know I wasn't running it when it happened or if it even happened.
It never use to knock but now it does. Also the oil pressure is lower not pegged, more desirable once it has all new seals.
Has anyone else ever seen this or had this issue?
Sorry this is Long but My Mind is full of doudt....
