PowerQuad Shifting Malfunction
Martenjg
New User
First time poster but am happy to be onboard.
I have a 6430 tractor with a PowerQuad transmission. I was bush hogging some thick undergrowth and the lights went out on my shifter and it no longer changes gears. To be clear I still have A B C D functionality but no 1,2,3,4. The lights on the console are also out. They do light up momentarily when I first turn the key but otherwise are dark.
I expect I tore something loose underneath??? Where specifically should I look and what should I be looking for? Thoughts?
Start by having a good look up underneath at any wiring that could have gotten snagged.
A friend's 6420 stopped moving a while back and was loosing oil. A harness had been snagged, and it tore the terminals out of of a pressure sensor, rather than simply unplugging the connector, causing the oil leak, as well as the electric issue!
