John Deere 2010 starts and dies
Hey guys! Dad called me last night while trying to cut hay and his 2010 gas won't stay running. Said he can start it, get it throttled up and engage the PTO and start going and it will just die. Sometimes within just a couple feet, sometimes after 30 feet. This was after he had made about 8 rounds through the field. Said its starts right back up, which makes me think fuel rather than the coil. What do you think? We just had the tank cleaned at the radiator shop and the carb gone through by Matt at Motec Engineering so it should be good to go as he tunes them on his dyno before sending them out. It was running just fine last weekend...no load though. Told him to clean the sediment screen and screen at the carb inlet and maybe see if it would stay running with the gas cap off thinking maybe the tank vent was plugged... Any other ideas? Thanks!!
Resister on IGN. switch is probably going bad . A new switch will take care of it . Also bad wire connections on switch can do it .
