4430 3pt hitch
Rich.Fl
This is a follow-up to my question several days ago. The problem I am having is when a 200 gallon sprayer is on the hitch the tractor/hitch will jump when in a mid-position. If raised all the way up it is ok.
Also, I have learned it does not seem to happen when the tractor is cold...first started. After running for about an hour it becomes a problem. Not sure if related but hitch bleeds down when tractor is off.
The nut on the linkage mentioned by Tx Jim seems tight.
I am looking for the screw Tim S said to adjust..." on the side of the valve there is a plug to remove then a flat screw driver go into that hole."
I have attached a picture...is it one of these plugs? I was able to remove the rear plug but was uncertain i could find a screw. The plug forward of this was so stuck I was afraid to continue unless I really needed to. Is the screw beneath one of these plugs?
Thanks Again for all your help,
Rich
Screw that adjust valve clearance is parts key 2 encircled in BLUE
Plug that one must remove to see screw slot is parts key 26
Thanks for the parts diagram Jim! I understand now and will try that adjustment in the morning.
Rich
