danny in draketown
7500# class. received my manual and it says to use white lead or equivalent to the threads of the head bolts if they were removed.
all but one of the studs came out. where do I get white lead? and there are 2 torque specs/125#.. and 150# for the black studs. mine look pretty black. it also says to soak gasket in oil before installing. the gasket I got has a metal facing on one side of it so I am assuming that it would go against the cylinder block???? the head is still at the machine shop but am trying to do some homework before it gets back. any input or suggestions would be greatly appreciated.
