Wheel Bearing Needed
CPeter
I am looking for a wheel bearing for John Deere hay elevator. The bearing appears to have the following dimensions. ID = 1.5", OD = 2.25" and Length = 2.5. I have the other bearing, but no access to the wheel or axle. This is for a friend who lives about 60 miles away. What I need is a part number or source.
CPeter
(quoted from post at 09:41:21 05/29/15) i dont know if this helps but have you tried jdparts.com
I would do JD parts but the problem is I don't have any of the following: part number, Wheel number, model of the hay elevator and it is 60 miles away at the friend's place. The nearest bearing supplier is also 70 miles away and they are iffy most of the time.
CPeter
Have you tried just taking the bearing to the local NAPA or the like? They can usually look it up in the book just by dimensions.
Google Baum hydraulics in Omaha,ne. You may be able to find 1 that matches in their online catalog, be patient it's huge, otherwise give them a call, pretty knowledgeable bunch, I buy from them on occasion and they've been good to me.
CPeter
Try PC 752 for Model 350. I have two hub assy. removed from a loader 30 years
ago and they utilize the 5129C bearings. The only number on the hubs is on the
cap. Casting #JD 2421-same as in the parts book.May not be same as your model but maybe a start.
Dave
Thanks, guys! I think you nailed it. I will see the owner today and see what he wants to do. Deere's price is $56.34.
CPeter
