Figured I should introduce myself. A couple weeks ago I picked up a '46 single wheel A. It's my first big tractor. Rescued it from a fenceline in the California desert. My plan is to get it running before anything else so I can better evaluate what it will need. The previous owner made a few modifications, most of which I will be getting rid of.
This is where we found it. I need to find a good used front tire and at least one rear. Obviously some exhaust parts as well. But it was practically free so I'm quite happy.
The wiring is a complete mess. There are about a dozen extra electrical wires and a few components, but not a single connector. Just wires wrapped around each other and smashed down with nuts. First repair was the starter. tI was a bit stuck and had a lot of crud in it, but the armature looks quite good other than minor rust at the pinion gear end. A light sanding and some grease got things spinning again. The starter switch needed attention also and is now making contact.
Here is is at home and after a light cleaning, and one of many questionable electrical junctions.
My big concern was that both stacks were left uncovered and the tractor has been sitting outdoors for at least 8 years. Radiator cap and fuel caps also off but that's not so bad. The California desert is a pretty dry place but it does occasionally rain.
Lucky me, the engine turns by hand. But before trying to crank with the starter I figured I'd check the fluids. Here is what I found in the gearbox. (the photo makes it look worse than it is)
Obviously there was a moisture problem but I don't know if it came in the exhaust, or if it came through a gasket from the cooling system. There is a lot of gunk sitting on the bottom of the sump but once I poked through it oil did come out.
I replaced the oil filter with a Napa 1242 as most suggest but the center opening of the filter is much larger than the old one. I put a larger washer on the bottom as a temporary measure but perhaps there is a filter that fits correctly?
I would also like to clean the gunk out of the sump and oil pump before filling with ATF and cranking it over. Is the oil pump supposed to drop out if I undo the two nuts and one bolt that hold it in? It drops down 1/2 an inch or so and stops. I do plan to buy a manual but for now I'm winging it.
