2755 steering
green field
New User
Hello, I have a problem with our 2755 steering. In the field doesn't seem so bad but when on the road you have to continually steer to the left to keep tractor straight. If you move steering wheel right tractor goes right just fine. To go left it seems that you have to turn the steering wheel quite a bit more. The tractor has a factory cab and is 4 wheel drive. Where do I start? Whats wrong and is it a big job? Thanks for the help. Much appreciated
I'll guess the steering unit has a leaking packing.
I'm thinking the steering cylinders are single acting, which would make the steering metering valve the only possible culprit.
