5 ft Gyra Mower
I have a 5ft. one that I use to pull with my H ,,I think it has the same gear box as the 7ft. ones.
Thanks Tim. I was just wondering if a 50 HP tractor would tear it up. I would bet its only a 35 hp gear box or less.I have some tall stuff I was going to use it on.
I blew the back out of my clutch last year with my 60,, the slip clutch didn't "slip",,,Darn it,,we should loosen them and let the slip a bit then re-adjust them,,that would improve the safety..but I hooked up to mine and didn't do that,, I was listening to the old gal pull and then the clutch hub let go....
Yes,, that's what happens to them when they set over winter, I got a couple with bad decks that I got cheap at a consignment sale for parts,,I do think the old Gyro mowers had the same gears and clutches..
