JD 318 Engine stops when I take hyro out of stop
woodsmanmark
New User
I was doing some light soil moving with my JD318 and blade when after hitting a big rut and getting quite a jolt, it stopped running when I move the hydro lever out of stop position. The battery light also came on. It will start fine and run, engine just quits when I move the hydro out of stop. Battery is new last year. Any help is greatly appreciated.
Mark
The seat switch was bypassed when I got the tractor - a plug with 2 wires and a wire nut. I'm not sure where those wires tie in after they go through the chassis under the seat. I wiggled them a bit to see if I could find where they come thru under the hood but couldn't see them. I went out this p.m. to tow it around to my garage, started it so my wife could steer, and the problem went away! Must be a loose connection where the wires tie in underneath somewhere, but I'm not sure where they go.
