rambler man
New User
just overhauled 830 es with std rings as the walls were what I thought were good to go. It now runs great and sounds good too. However it has plenty of blow by but the problem is it spits oil out of the crankcase vent that is on top of crankcase. The baffle is in place as there an oil storm above the rods. oil pressure gauge showed H so I dropped it down to M with no help. I know some work for it would be good. Any thoughts on this. Also connecting the batteries does the hot positive go on the solenoid or does the negative one go there. any info would be appreciated and thank you in advance, rambler man,
