How you get clutch pto shafts out on 4010?
Putting new clutch in 4010 diesel. Need to change out the oil seal in case
between clutch housing & transmission that's leaking. How do you get to it? As
the clutch & pto shafts will not come out! What am I missing/doing wrong?
You will need to split it again at the transmission case,,they come out the back, and as you go for the seal you will see that the bearing will need to come out too,, a bit ornery, but not bad, it would be a good time to inspect the PTO shift pins while your in there...
