Hi all -
I'm new to this forum so I apologize in advance for any "discussion board faux pas" I might commit.
I am in the process of restoring my Dad's 1949 Model A John Deere and even though I'm only at the point replacing a rear wheel bearing and have not started to do engine work... there is something that i remember about the tractor that was a problem and I wanted to see if anyone else has had seen the same issue.
The problem was this - it is electric start - and when it was cold, it always started right up. But after it was run for a while and got warm/hot it would not start. My uncle tells me that my Dad was pretty good at setting the throttle just right and get it to start hot sometimes... but my uncle could never get that to work for him.
I have an old Yamaha golf cart that had the same symptoms - and I realize that there is a WORLD of difference between a mid-1970's Yamaha 2 cycle engine and a 1949 Model A engine... but with the Yamaha engine, when it got hot the block would expand and basically ruin the compression enough to make it so that it would not start. I had it rebuilt and re-bored and it works like a charm now. I'm sure that the tolerances are not nearly that tight on the Model A, but could the problem be similar? Compression loss?
My Brother in law guessed it would be more of an issue with the magneto or ignition system - but I don't know how heat would affect that.
Any ideas?
Scott
Any ideas?
Scott
