MaverickM23
Mixed feed with our 4020 yesterday and 3/4 of the way through the mixer started to bog down I looked at the tractor and it never changed RPM's, shut
the loading auger off and let the mixer catch up. Im assuming this means that my PTO clutch is slipping. I plan on splitting it and doing the work
myself. I have the IT manual and also the JD Service manual. Is it as simple as taking the clutch apart and putting in two new disks, adjusting the
settings and putting it back in? What else should I do while I have it split, I think I read most guys do a rear main any other areas to look at?
