70 3-point - series 801
deanpost
New User
We are looking for information/specifications on a "centering bar" (DA 5941 A) . Rebuilding a family heirloom and need only to make (or buy) this piece to complete it. Thanks for any help. Dean
like this
yes, ours is just like that without the chains. the piece we're looking for specs on replaces the chains and is a triangle between the two draft links.
that would be a good name for it. just an "a" frame that fits between the two draft links at the top of your picture. it mounts in two places on one side and one point on the other. makes a ridged 3-point. appreciate your interest very much. never know where info leads. thanks !
DA5941 A centering bar : pic from Fotki: Author deanvp ? // Pics from parts cat. dif. types, styles, centering bars, sway braces, tie bars; JD used with dif. Imp's ......... .... magnify pics ...
that would work fine. we show the tractor and are putting on a "pan breaker" . want it as original as possible. your tractor looks really good !
thanks ! exactly what I'm attempting to create. the drawing in the parts book will work fine, I was just attempting to get the actual specs (which may not exist)
yes, I have the mast on the pan breaker. just down to the "fine points" now. could work with chains but I grew up with it having the a-frame so would like to continue that.
I'll try an measure one of mine [later today] & get some cat.II dimensions & spec's / Pic of one on "Fotki" author deanvp / seem to be home made , not factory... ? Is the deanvp site on 'Fotki' yours.. / lots of interesting 800 hitch parts; well done..
You don't need all that crap...!
Just use a short adjustable link between the draw-bar and the left lower link..
AND, use a few large washers and an "Eye-bolt" thru the "Evener-Bar", to the 3-point equipment..
Works just fine and not any problem at al..
That "Horse-Head" is over-rated at best and high-priced at worst..!!
Ron.
thanks ron, but what I'm doing is attempting to bring it back to what I (dad) had when I was a kid. one of those sentimental things I guess.
Dimensions of metal: 2 plates, 1/4+ thick, 1 1/2" on top ,4" bottom , 10 3/4 on straight side; Angle,[top] solid bar, 3/4 X 1 1/2, 27" long ; bottom solid bar, 3/4 x 1 1/2 ,26" long; 2 tabs [with hole] 1/4+ thick , 1 1/2 x 3" long; ....... Hole pattern [center to center] 9 1/2" side , 28 3/4" bottom , 28" top; ..... Top solid bar welds 4" from top of plate..... see pics.. NOS DA 5941 A with original pins...
ABSOLUTELY perfect !! wish I could do more but a big thank you will have to suffice. also thanks to dan. the photos and specs will bring it together. it'll be in waterloo.
