2510 3pt weak lifting
Brokeiniowa
New User
2510 3 point will not lift as much as it should, it will pick up a bush hog mower but any thing much heavier will stop it. The lever moves fine arms go all the way up and down like they should, does not settle overnight. Everything seems normal until you put some weight on it. What is the problem? thanks
1st thing I'd suggest is check stand-by pressure which should be 2250 psi. Have you tried moving L/D lever to a different setting? How Long since hyd filter was changed?
Filters get good service, yes I have tried moving the LD lever, (I should have mentioned that) where do you tap in to check that pressure? It is a powershift tractor and shows good pressure on the dash gauge at higher RPMS if that would be the same pressure you are talking about.
Thanks for the response.
