Jdtractorman123
I have a 1959 630 standard gas tractor. It's a solid tractor that came from Canada and all the lights even the dash work. The engine when it runs is stout and no oil smoke and or blow by. The tank was fuel of crud when I got it and the oil pressure fuel bowl needed attention. I have always heard bad things about these things and now I am a believer. I have cleaned the tank, installed new gasket on oil diaphragm, new bowl gasket and cleaned it out. Ran great long enough to get it out away from shop 200 yards and die... I pressed the scre on top of fuel bowl I could see gas coming down. Hit the switch and it cranked back up! Got on her and put in gear for it to die again... Waited 3 min tried and nothing,,, the tractor shows good oil pressure when running. I spent 30 min trying over and over to get it to run 5 feet then die. It has enough gas in the tank but it's like the oil pressure cannot keep the gas coming in even with new seals. Is the diaphragm suppose to pulsate or just open and close? Would a new spring be needed?
Thanks
Thanks
