plfiremanc8
New User
have a 4030 tractor with cab and 2 remotes that I had the load control shaft seals replaced on a while back, since the new seals were installed the 3 pt hitch only works in the lowest position on the draft control, the lift barely works now, I understand that it's possible the load control arm finger may have fell out that rides on the shaft, does anyone have any insight on how to repair this?
I have removed the load control shaft to take a look, appears the finger has fallen out of the arm, what is the best way to get the finger back into position?
Thanks Joe
Thanks Joe
