630 handle a 10ft Deere 115 disk?
IIRC the 115 was a light tandem disc so it should not be a problem though duals would be nice.
First of all, you better measure the width of your disk again. The smallest model of that series was about 11 1/2 feet. This being said, odds are you can pull it ok. In softer dirt you will know it's back there. Mike
That's kinda what I was thinking too. But what little disking I have done I have no idea how wide they were.
(quoted from post at 13:06:57 05/01/15) First of all, you better measure the width of your disk again. The smallest model of that series was about 11 1/2 feet. This being said, odds are you can pull it ok. In softer dirt you will know it's back there. Mike
According to JDparts.com PC1736
GANG FRAME AND STANDARD, NARROW FRAME
185 MM (7-1/4") SPACING
2.3 M (7'8"), 2.7 M (9'0") AND 3.1 M (10'2") SIZES
Yes, it probably would..... Until you lowered the disk into the ground!
We pulled a 12 ft 4 inch Kewanee disk with our 4010-D. It struggled on some of the steeper hills in plowed ground until we had the pump turned up to 100-105 HP. Then it would pull them in 5th gear. We did have axle mount duals. Disk had 20" rippled blades on 7-1/2" spacing.
Jim, I won't argue with what you found. All the sales literature I have list the 11.5' size as the smallest available. The only disk of that vintage I have heard of is the 100 mounted disk. I have literature on the 110, 111 and 115 and none list anything smaller. I stand corrected if that is true. Mike
My 1987 Deere disk brochure shows the smaller sizes.
Only 21 ft disk around was pulled by a 1206 back in 1965. 4020's pulled 14-15 ft tops. And 1/3 to 1/2 of the 4020's were turbocharged.
