60 all fuil
rick deere
1953 yr modle, no power steering, needs steering wheel, no live pto, pto don't work, think coupler is broken, manifold gasket burnt out,, , does run and has end play, but crankshaft is good on the clutch side,no little fuil tank, fair rear tires,what kinda offer should I make, seems like it comes with work .Thanks p.s. narrow front
I would agree $750.00 to $1000.00 with no starting fuel tank. If it wasn't all fuel I would guess $750 or less. Too much work for what it would be worth in the end. That and the first numbered models just don't seem to sell very well. Just my opinion. Bob
Yes I have seen them with the small tank on them,, and I have a single front laying out back off a 60 LP
The single wheel would be the "normal" style of narrow front in regions with furrow irrigation so in certain areas of the country they are much more common than dual front tricycles. (Dual fronts just don't work in furrows.) Based on the piles of single fronts I've seen laying around in used equipment yards in such regions I'd guess they made quite a few of them.
I think it was from #6000000 - 6013899 that they used a single barrel carb #72 for all fuel, then they used a #84 for the dual induction carb all fuel if what Im reading is correct
