1010 leaking fluild
dewy
friends 1010..leaking some times out both sides of bell housing ,where the small and big peep hole doors are......also leaking under seat hydralic area.....last but not least head gasket area....how hard to put on gasket on that motor and what in the world would be coming out those peep holes.....and how bad is that leak under seat.....seems like most deeres i see are leaking in that area....im more familar with farmalls and was trying to help a friend slow down some leaks on this hulk beast.... thanks for input dewy
Loosen gas line at carb , once you have a good dip use 10 foot of toilet paper as a fuze light and run , the easiest cure for a pile of ####. Lol 's just giving you crap a little time and a lot of patience you will have her as good as those farmall 200's
