gf in S.IL
I looked at a 3020 diesel powershift tractor that is for sale. Two things that I have concerns about are: (first) when the shifter is moved to any of the forward or reverse gears, and the inching pedal is pushed down, there is a very slight creeping of the tractor until you press on the brakes. In trying to research this on the internet looks like could be anything from "that's normal" all the way to "warped disks in clutch packs and will need to rebuild the transmission". It does not creep in the neutral position and goes into park very easily. (second) to stop the engine you pull out on the end of the throttle lever and push it up past idle. That does not always work to kill the engine on this tractor. Is there linkage to the injection pump that can be adjusted?
Am impressed with the tractor otherwise.
