IAtractorKid
Hey guys! Helping my dad with his 2010...need to replace all 4 tie rod
ends. Naturally they are rusted up so we can't get the assemblies
apart, and the ends for that tractor are awfully expensive. So the
question is, will a 3010/4010 tie rod assembly work??? Have seen
#AR44334 and #AR44332 available...does anyone know and dimensions of
these??? Specifically the longest and shortest lengths it can be
adjusted, diameter of threads, and diameter at the top of the taper.
I'm thinking any assembly, even a universal would work as long as it
would adjust to the right length and has the right sized ends. Thanks
for the help!!
P.S. - On dads tractor, the tie rod assemblies are 21.75" center to
center, 9/16" threads, and 5/8" diameter at the start of the taper.
for the help!!
